Exhaust Question
Will it fit?
  • Yes
    Votes: 0 0.0%
  • No
    Votes: 0 0.0%
  • Total voters
Another idiot
Vz Ute
Hey all
I have a custom exhaust made for a vz Ute
I’m also looking to buy a vs siii statesman
I know statesman’s are long wheelbase but are they compatible with that gen of exhaust
Looks to be a very similar shape at a glance
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
In short, no.
But with a grinder and welder you can make anything fit.
StephenM
71
Innot Hot Springs Qld. 4872
VS Equippe Series II
I got a rear section off a VS wagon to go on the sedan and it needed a bout 150 mm cut out of it. As above welder and grinder.
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
Impressive, seeing that the bend where it goes around the tank on the wagon is completely different to the sedan. I'm surprised it fit between the tank and the spare wheel well as the spare wheel lays flat in the wagons so the well is not there.
Another idiot
Vz Ute
In short, no.
Looking for an exhaust at the local wreckers and they have none for a vs statesman but have a WH that has one that looks identical.
We’re those 2 models compatible?
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
No. Would be the same as trying to fit your VZ system on the VS.
losh1971
North Tas
VE Series I SS Ute
Not sure if Redback make a VS Stato kit but it's worth a look. If you want something fairly inexpensive.
StephenM
71
Brain fart. It was the middle muffler.
Similar threads
