exhaust systems
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by TINYTIM, May 8, 2006.
  1. TINYTIM
    TINYTIM New Member
    VX SS
    looking for ideas on extractor/exhaust systems combinations for gen 111 motors......my vx ss currently sounds like a 4 cylinder........HELP!!!!!!!!!!
  2. raff
    raff Member
    Brunette, 5-10', 10D's, great personality
    There are likely a tonne of threads on this topic already but simply catback are a good place to start. Most off the shelf systems do a good job for this, like redback or difilipo.
    Cats are a worthy upgrade but can be pricey for hi flow aftermarket cats. Try get some from a VX clubby and open them up to 2.5 in the inlet/outlet.
    Headers are a good investment over the stock SS cast jobbies. Again clubby headers are around for cheap or go the aftermarket headers like pacemaker or Difilipo. There are many varying opinions on this but generally there are tri's and 4-1's. Im told tri can give u more down low and 4-1's more up top. Unless you planning big mods later tri are good. If you plan to open and mod the engine later with cams, heads etc 4-1's may be a good option here. 1.5' collectors are good for auto and 1 5/8 ot 1 3/4 are well suited to manuals.
    Another extremely cheap option is to remove the rear resonator from your existing system, it makes it louder but not necessarily better sounding. And can create terrible drone.
    Look at around $1500 for a full header, cat, catback system on a budget and as much as $3500 if you splurge.
    More importantly aa well flowing exhaust will make a big difference to the power of your SS and well as the sound. :dance:
    Raff
  3. minux
    minux Infidel Bear
    For a top of the range system, you wouldn't need to spend more then $2500. For just cat back expect about $600? Header's between 700 and 1100 depending on brand etc, cats around $350 each for good steel high flow's.
  4. raff
    raff Member
    My top of the range system just about would! Coated headers fitted $1100, stainless catco cats $800 and stainless sureflo catback $1300 (like to see a $600 stainless catback, or is mild steel top of the range :whistling ). Stainless tips $100. Oops only $3300, close
  5. Claybo
    Claybo New Member
    Cronulla, NSW
    VU 5.7L
    Will the 6.0L exhast from headers back bolt straight into 5.7.L?
  6. st3r3otyp3
    st3r3otyp3 Donating Member
    WA bruz
    VX HSV VX SS
    VZ?? It`s good that you dug as the world dont need another exhaust thread.
  7. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
    Yes it will, as long as the body is the same, EG: sedan - sedan, ute - ute etc. The only exception is the VZ Clubsport that has the pipes side by side behind the cats, but even then, if you are replacing everything from the engine, it should fit.
