Exhaust
Shawno31
Qld
Ve ss
Hi guys new to the ve ss commodore scene, just wondering if a VF series 2 mid section would fit my 09 VE SS at all, cheers Shawn
ChRiDDa
N/A
VE SS-Z Sportwagon
Sure will
The only thing you need to watch out for is that sedans and wagons are interchangeable but not utes..
The rear mufflers are slightly longer - won’t be an issue 8n your case, as your only using the mid section
VS 5.0
What benefit is there in swapping a VF II mid section for a VE mid section ?
krusing
Melbourne, Bayside
Aren't the fitting for the rear mufflers different for a VE to a VF,
Where the VE use a 2 bolt flat flange, and VF's use a compression clamps type fittings.
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
Not all VF's use compression clamps, some also use the 2 bolt flange.
Shawno31
Qld
Ve ss
It’s only because mine has a gaping hole and was given the vf 2 for free
