Topcar said:Thanks for your reply minux. When you say "no MAF", do you mean the MAF sensor is disconnected for the tune or the vehicle has no such sensor fitted?
Topcar
ringram said:Ive seen the tune, so I know there is no rocket science there. Im aware cam and heads are slightly different, though I wouldnt imagine too much else was changed. I would have thought a mafless tune would pass all emissions requirements. Unless one of those reqirements was that the vehicle cant be modified from stock, in which case any car with headers would fail.
Do you know what mods were required to be compliant?
the reason for removing the Maf is because of the restriction it causesringram said:Ok cool. Just gut the maf leave it in, but disconnected, or connected, but disabled in PCM. Nobody will be any the wiser.
