Extractor fitting!
VEARGH
"Stop,Drop..KaboOm.*
Penrith.
v_R
Hey have any of you guys fitted extractors/headers yourself? im stuck! im finding it difficuilt to undo the bolts on the right side where the cat and extractors meet? anyone found a way around this?? please help out if u can.cheers
digisol
Central QLD
Toyota Landcruiser
Yep, on several vehicles, it's called a gas axe, grinder and a TIG welder.
rarely do extractors fit properly, it's best to pay the guys that do dozens a day, they have the right tools and do it heaps faster for stuff all.
Stupa
35
VU Storm
a breaker bar, a big hammer some crc or wd40 and persistance, lots and lots of percistance
digisol
Central QLD
Toyota Landcruiser
Ya also get a workmanship warranty, and the knowledge of someone that really knows the what and why of exhaust systems.
One of my pet HATES is somone that has a stock car with an overly noisy exhaust and using the choke to make it sound like it's got a lumpy cam, or those fake blower intakes, get a grip.
Back on point, noise will do nothing but attract the cops, ya might as well put a flashing light on the roof.
VEARGH
Penrith.
v_R
nah ive got it off now, but that same side is a pain to put on!! ive got all new gaskets so it should be full sealed! it looks like something to do with power steering that is in the way!? anyone else done this before?! arghhh its such a pain!!!
markovr
60
northside brisbane
www.cardomain.com
07vessv 94vr .04vz wgn,93vp wgn,82 vhV6 wgn 88 vn
Most extractors need to be installed with the power steering rack unbolted from the crossmember and let loose to hang on its hoses and tie rods to give you clearance.You have to undo the the input shaft coupling by removing the nut and bolt amd sliding off the coupling and with the 2 large securing bolts removed from the crossmember ,the rack will slide out and hang down to fit the extractors.
After fitting the extractors bolt everything back up and check for clearance...I did a bit of precision grinding on that righthand flange to get clearance that Ithought was enough.
VEARGH
Penrith.
v_R
Cheers mate hopefully i can get it them back on now..
