Extractors and 2 1/2 Exhaust
Discussion in 'General' started by akust0m, Feb 16, 2008.
  1. akust0m
    akust0m New Member
    2000 VT II SS LS1
    Hey I don't know a great deal about cars, which is why im asking this question. Im looking at these extractors which says the following:
    1 5/8 primary pipes and 2 inch secondary pipes
    What are the primary pipes and what are the secondary pipes? And also I'm thinking about buying a 2 1/2 exhaust of some sort. Will the exhaust fit properly to the extractors? Any suggestions as to what brand/type of exhaust to get?
    Thanks
    Chris
  2. 1991_Vn2nV
    1991_Vn2nV New Member
    Gumeracha, Adelaide Hills
    91 VN Berlina & 03 VY Berlina
    Primary pipes are the pipes that run off each cylinder on the manifold, which then combine to become the secondary pipes.
    A 2.5" exhuast will fit fine, i'd go with Lukey if you're just after something basic.
    What brand are the extractors, whats your budget?
  3. akust0m
    akust0m New Member
    2000 VT II SS LS1
    Oh yeah...ahh they were some MPH brand or something. But in the meantime I've found some second hand Genie ones. How much would i be looking at for new extractors? I've heard that pacemakers were the best, but then I've also heard that your pretty much paying an extra couple of hundred for brand name and that they're pretty much the same as other brands. What would you recommend?
  4. akust0m
    akust0m New Member
    2000 VT II SS LS1
  5. 1991_Vn2nV
    There are only 2 brands i'd go for mate, Pacemaker or Advance. Others will also reccomend HM.
    Pacemaker easily have the best build quality, and will outperform cheap headers such as the ebay ones, Lukey, Wildcat etc. I would spend the money and get the Pacemaker competition headers, but you're looking at $600 fitted.
    Advance will offer the same performance gains as Pacemaker with perhaps a slightly lower build quality, but you can pick them up for about $450 fitted.
    Genie are a good brand, but i'd check the condition of the headers and how much they are asking. Dont forget they still need to be fitted. No warranty either.
  6. akust0m
    akust0m New Member
    2000 VT II SS LS1
  7. 1991_Vn2nV
    They look a little worse for wear to me.
    If you get second hand try and get a stainless steel set, as mild steel does rust over time. If you purchase new mild steel, you can also get it ceramic coated like mine so they look chrome but it protects the headers from heat and corrosion. Shop around for prices, but i'd say Advance are your best bet. Great performance, great cost.
  8. akust0m
    akust0m New Member
    2000 VT II SS LS1
    Ok thanks mate :thumbsup:
