EYY's HJ Ute
EYY
VS Statesman
Twin exhaust is fitted along with extractors. Very happy with the sound but the system I had wouldn't fit. I had to chop it up to make it fit.
Went cruising with Sandman a couple of weeks ago though.
Gaiter
VZ SS Thunder
Looking good fellas!
EYY
VS Statesman
So I've purchased one of these.
It's a procomp 4150 style throttlebody. Received it today and seems quite well made and should be able to work with it. Very smooth throttle action with the ball bearings on each shaft. I've purchased a cheap $15 TPS from a V8 ford bronco (as it fits and turns in the right direction), and the GM IAC supposedly fits.
Also purchased an NVRAM for a '424 pcm along with an autometer electric speedo and plan to run the electronic auto. I have another VS V8 stato sitting at home currently which I plan to fit all this gear to and get it all working prior to doing any work on the ute. This means that when I fit the new engine I'll be able to start it and run the cam in straight away without any messing around. Pics to follow as it progresses.
losh1971
North Tas
VE Series I SS Ute
I love seeing your work EYY. You certainly have a real talent, its great.
gtrboyy
vt ss & lc gtr
Waiting for EYY to score cheap 6/71 vn efi set up for that next!!!!
Then maybe haggle him for single plane or come manifold lol
EYY
VS Statesman
Found a set of draglites too cheap to pass up. Test fitted one of the rears today and looks like it'll fit without too much drama with the 275/60/15's. Hopefully won't need to touch the lip either. Apparently they were on a hx panelvan and didn't touch anything without the guards rolled so we'll see.
