T700 can be a bit tricky to setup, but mate, once they are theyre frikken amazing.
383 hatch, how did you go about hooking your speedo up in your ute?
I run an inline speedo drive. It screws on the auto as per normal, has the speed sensor wires coming out of it to wire up to the ECU, then the original speedo cable screws on the end to drive the original mechanical speedo. The other way to do it is just run an electronic speedo, but there was no way I was hacking up my GTS dash to fit one. They're getting too sort after to modify. The other reason is, you wouldn't know my car had an injected motor with the bonnet shut as the rest of the car is fairly old school, that's the way I like it.
the main problem i had was with the TV cable, but ive just realised that since its for a 304 its already setup anyway. so thats easy. just needa get a x-member and shorter shaft and youre laughing.
