For Sale is a Borg Warner, 2 pin, 28 spline, LSD diff centre out of a VS SS. Still locked up both wheels when tested in the car BY HAND, but suggest a bit of machining b4 fitting (about 4mm machined off the clutch cones and a few thin shims), this would be a cheap job to do and will extend the LSD's life for a long time to come. Clutch cones themselves still have a deep 'twirl' groove thru them, which shows that it is in original untouched condition as it came from the factory. As most will know these LSD units are quite rare and expensive, even in heavily used condition (up to $450 used from wreckers). I bought one for my own car 8 months ago in much worse condition than this one for $170 , mates rates! Will suit all cars with 28 spline axles: VL Turbo, VN- VS (all live axle) and VN-VS IRS too I THINK (not sure). Get in quick.. First in best dressed! $200 take it away. PM, call or SMS me 0404152460 Prefer local pickup, but will send at buyer's expense. NO TIME WASTERS PLEASE Gilbs
Will this fit a VR V6 live axle without any other parts needed ?? Do you know somewhere to get the machining done ?? Where are you in Adelaide ??
This part is all you need mate! it replaces the open wheel centre, use your diff gears on here too. Best prices, and only place i go to, are from BOSS Differentials in Lonsdale S.A. They will cater for all diff requirements.. machining, fitting etc. I am located in Camden Park S.A just off Anzac Hwy. 5 mins drive from Glenelg. If you're genuinely interested call me 0404152460. Gilbs
