Deuce
Super Stock
- Feb 5, 2012
- 4,489
- 4,715
- 113
- Location
- Snobs Rock (or so the locals say)
- '94 VR SS V8
Loving the updates. I strangely quite enjoy wiring, so the last few updates have been great.Bit more progress, finally finished off the majority the the electrical work on this. Starting with the stereo, I added a JVC KMM745BT stereo. I wanted cheap, capacitive touch screen and android auto and this came up as the best bang for buck. It seems pretty good so far too. I 3D printed a mount which fits nicely into the dash in the hacked hole by the previous owner. With this I also added a switchable reversing camera, which allows be to adjust where the camera points for backing up to a trailer etc. This is by far the biggest car I own so I though it would be a worthy addition. Again a 3D printed mount was made to hold the camera utilizing the factory number plate positions. Not 100% sure how well its going to last out in the weather but worst case if it dies I print it out of something different or make a similar one out of metal. When I removed the gas system from this I was left with a nice big hole in the dash to the left of the steering column and the camera switch was the perfect thing to cover this up. I was never going to be happy with the wire running over the dash and back under the dash, so another 3D printed part to both hold the switch and allow the wire to be routed back under itself neatly and through the hole in the dash. So fairly happy with how it came up.
Next thing was the tray lighting, I showed a while back how I added all the led lighting around the perimeter of the tray. Well I finally got around to making up the switch panel for it. The lights themselves came with an inline dimmer so I retained that and added an inline switch and housing. The wiring was then routed down behind the LH tail light which then ties in nicely to the DT connector behind the rear bumper. I added a phone charging port too, as I plan to take this camping too, I swapped out the cigarette lighter for a twin USB plug and wired up a switch on the dash to give these power even with the ignition off. Final thing is the electric brake controller which is pretty self explanatory and very boring, but its in and wired up. Which is good as I need to drive it to Winton for the 6th Feb, so better get on with it.
Mount for the Head Unit
Potato photo but you get the idea
Switch mount, prototype on the right, final on the left. Back side showing the wire path and clip mechanism.
Camera mount with wire path
Camera installed, gold bolts are hideous but they were all I had on me.
Tray lighting switch panel
Wire routing inside
Installed
Phone charging switch and brake controller. Brake controller is in a funky spot so I'm not looking at it all the time whilst driving.
I am amazed by the 3d printing, as I have never done this or been around it being done. It looks great.
