factory fog lights not working
kyevswagon
vs wagon 5sp
i just wired up some ss foglight in my vx used the factory wireing put the switch in and pluged the lights up n put relay in turned them on and there not working im not sure why but would any one have any ideas
accentstencil
71
Caboolture South, QLD
WH II Caprice, 5.7 2018 Equinox LTZ V
I'm pretty sure there are two similar connectors behind the dash, one for the fog lights and one for the lights always on option. Have a good look in there and see if you can find the other connector.
kyevswagon
vs wagon 5sp
yea its all been pluged in up behind the dash there was a black plug for the head light switch and a clear blue on that was taped to the loom which i connected to the fog light plug
accentstencil
71
As I said, there should be two unused plugs ( at least there were in the VT), see if you can find the other one. You might need to have a real good poke around.
