Factory Fog Lights
cypher967
HSV VT 5.0 195i
VS Commodore S
Hi, I have installed a new dash wiring loom with the fog light switch, the switch all lights up when parkers are on. but i dont know where to connect my fog light so i can use the factory switch any ideas? Cheers
Ben
H
HATER VP
Guest
Look for some black oval plugs near each head light. They are possibly clipped near the side of the radiator.
cypher967
HSV VT 5.0 195i
VS Commodore S
Nope I havnt got any there, does holden still make a fog light loom?
gdobbie1105
yagoona
VS Calais V6
fog lights
hey there
i have just installed fog lights into my accliam
luckily i had the wiring and harness under the bonnet but not in the engine bay. if the wiring is not in the bay you will have to wire it up your self as the harness connects into other harnesses and i do not think that holden does sell just the engine bay harness for the fog lights.
if there is no relay in the main box near your battery then your car does not have the wiring installed.
hope i have helped.
if you can wait until thursday i can get my hands on a wiring diagram for the headlight and foglight system that i can scan and attatch
glenn
N
nemodore
Guest
hi guys just need to know what pins on the back of the fog light switch do what , any help would be greatful
markovr
62
northside brisbane
youtu.be
07vessv 94vr .04vz wgn,93vp wgn,82 vhV6 wgn 88 vn
struggo
Old Sydney Town
2016 VFII SSV Redline + 2013 FG MKII G6ET
Heres the fog switch side wiring http://forums.justcommodores.com.au/attachment.php?attachmentid=23791&d=1154263414
and the under bonnet wiring http://forums.justcommodores.com.au/attachment.php?attachmentid=5961&d=1126991624
The pink/ red wire is installed in most looms already from instrument connector yb 124 near the fuses inside the cabin through the firewall to the relay base under the bonnet.
Hi markovr,
I'm installing fog lamps into my VS series 2 Berlina. I have connected the fog lamps at the head lights, the relay is in place yet when I look behind the facia I don't appear to have any connection. :cry:
Any suggestions would be greatly appreciated :thumbsup:
Struggo
markovr
62
northside brisbane
youtu.be
You will have to pinch a plug ot of a wrecked vr/s that runs to the air con switch as it is the same plug that goes to your fog lamp switch and wire it up as per this diagam http://forums.justcommodores.com.au/attachment.php?attachmentid=28567&d=1161226018
might mean moving a few wires around in the air con plug that you got from that wreck...if you went that way
I can supply you one with directions with the right wire connections for a six pac (I like beer) if you get stuck.
