warrjon
- Jun 21, 2009
- 84
- 1
- 8
- Location
- Victoria
- Jaguar XJS V12 & VXII Super6 Calais
The turbo never helps the SC turn. - the SC's rotors are basically sealed against the housing, and it doesn't let any more air through than what it's suppsoed to when it turns.
The SC is spinning at a fixed rate with the motor. if the turbo is supplying more air than the SC is supplying to the motor with atmospheric pressure on the intake, it doesn't 'help' the sc turn and somehow magically drive the SC or engine. - rather, it creates a point of restriction for the T/C air, and there is a build up of pressure against the supercharger rotors. - the rotors continue to turn, and simply move the *pressurized* air from one side of the blower to the other - into the same volume. so you get that whole 'compound boost' effect. (so, the blower is not a restriction for *power*, but it is a restriction for the turbo->engine air path, obviously)
Kinda but not exactly. What the SC will do is take the inlet pressure and pressurise it via its pressure ratio.
The pressure ratio is set by
SC rotational speed (pulley size)
receiver volume (the engine)
The SC wont restrict the TC all it will do is compress what it sees at the inlet.
To give an extreme example lets take a 6psi SC pulley. This is 6psi at sea level if you take your car to 15000ft this same pulley will only give you 3.3psi boost. this is because at sea level atmospheric is 14.7 psi but at 15000 atmospheric is only 8.3psi. This same will apply if the inlet pressure rises either by being below sea level or by adding boost pressure to the SC inlet.
This is why the Spitfire used a 2 stage supercharger it basically had a 2 speed gearbox to increase its speed at altitude to maintain boost.
Hope this helps with the design.
Just remember flow through the SC will increase as SC inlet pressure increases or the air temperature drops. So IC prior to the SC.
