Factory LSD Ratio
SaGe
VS II S-PAK Manual
hey all,
does anyone know the ratio of the factory holden LSD in a VS
sircruisealotVS
39
South Brisbane
VZ LS1 Calais
the ratio is 3.08 for an auto and 3.45 for a manual. but im not completely sure whether that applied to the lsd diff as well, or whether the lsd diff's where all 3.08 regardless.
Immortality
Staff member
Sth Auck, NZ
i always thought they kept the ratio as is and just fitted an LSD diff. easiest way to check your ratio is to jack up the car, take a wire brush to the collar around the input joke on the diff(where the driveshaft attaches to the diff). the ratio should be stamped on that. failing that, remove the diff cover and rotate untill you find the info that is stamped on the diff gear, there should be a serial number and a ratio number as well
W
whisky
Guest
I'm pretty sure it's 3.08 regardless of auto and manual.
But yeah the LSD's are all still 3.08:1
Infus10n
Holden Captiva (Work Demo)
My diff says 3.08 and mines the 5 speed getrag manual.
SaGe
VS II S-PAK Manual
yea mines 3.08 and mines getrag aswell. i wish i had a 3.45 LSD
