Factory stereo and power issue
Discussion in 'VY Holden Commodore (2002 - 2004)' started by 1_johnboy, Oct 15, 2011.
  1. 1_johnboy
    1_johnboy Member
    east gippsland
    11` VE Omega
    I the other night removed the setreo thinking that was required to access the loom to install a bluetooh car kit. As I found out its not needed, as a result I had trouble removing it and blew a the fuse on the back of the stereo. I replaced it and it powers back up.....but is unusable, screen lights up clock works but cant turn it on.
    I`m installing the car kit with the plu on the passenger side centre console. There is no ACC. power to the loom, constant is fine.
    I`m guessing the two are linked, I have checked the fuses and replaced, still no good.
    Any suggestions?
    Are there other fuses I should be looking for?
  2. hakhawk
    checked all fuses under the steering wheel?
  3. 1_johnboy
    1_johnboy Member
    east gippsland
    11` VE Omega
    yeah they all look good
  4. MEESEN
    MEESEN "SOON"
    '03 VY
    Make sure the stock headunit is pushed right back in, if its not it sometimes doesn't connect properly to the loom
