Hi all, Having a bit of a problem with my old girl... it seems that all of a sudden the fan won't turn off when you turn the car off, have un-plugged the fan for the moment... any suggestions? Is there a thermostat in the fan that could be dead?? Would appreciate any help or suggestions.
Well... i think so... it smells like its hot but the gauge is sticky... so don't know for sure... starting to wonder if its a relay thats got stuck... the fan has been a bit intermittent for a while
you mean to say that the fan doesn't turn off when the key is out of the iginition? or does it just stay on while the key is turned to 'ign', but goes off when you pull it out?
Im not sure but check the sensor switch located on the bottom of the radiator which regulates th switching on and off of the fan it may be malfunctioning.
on a more serious note, check your fan relay I'm guessing it's stuck on! (fan relay located in engine bay near battery)
don't know... but very weird. Hope not either of those things any ways... not too handy when you have a baby in the back seat!
Thanks... was wondering if it could be as simple as that... will check it in the morning... thanks alot
