fault code 16 on vs v6
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by 1_johnboy, May 15, 2011.
  1. 1_johnboy
    1_johnboy Member
    east gippsland
    11` VE Omega
    CEL just came on, car decided it wouldnt change gear(manually would) - assuming "limp home mode" enabled. CEL goes off changes fine. Seems to only come one when the car warms up........not my car so I dont know at what temperature
    So got code 16, incosistant voltage to temp sensor. So I`ll check for a constant supply for 5v and condition of wiring.
    Is this the sensor near the goose neck?
    Is there anything else I could be checking for while I`m at it?
  2. db_notso
    db_notso diagnostic technician...
    sunshine coast, qld
    vt v6, mods(susp brakesetc...)
    Code 16 - Coolant temperature Sensor voltage unstable
    so could be loose terminals at the temp sensor? or loose terminals at ecu? or dead sensor? or broken wire from sensor to ecu?(last one unlikely)
