fault code 22
callum87
vr executive series 2
Code 22 - Throttle Position Sensor (TPS) - Voltage Too Low - Auto Transmission Only. what does this mean and how do i fix it
hako
Donating Member
77
Toowoomba SE QLD
VS11 BT1 V6
Unless your car is playing up, the first step is to clear the error code by disconnecting the battery for 30 seconds. If the error code comes back then look further but first make sure its not just a "glitch".
kopper69
34
VRII Acclaim
You can also remove the 20A engine fuse, in the fuse compartment under the bonnet. Same procedure, 30 seconds, but this method is just a bit easier. Also means you wont need to play around with the battery terminals, which can be risky and cause problems if you arent too experienced.
