Fault Code P0502 HELP
Heffo72
Moree
Ve SSV UTE G8
Hey getting fault code p0502, replaced rear harness and wheel sensors anything else I should check? Replaced battery as well.
krusing
Melbourne, Bayside
Sounds like the you have knocked/disturbed the Speed Sensor connector while replacing the rear harness,
P0502
Vehicle Speed Sensor (VSS) Circuit Low Voltage
ECM
DTC P0501 or P0502 for the Aisin AY6 transmission
or
DTC P0502 or P0503 for the Tremec 6-Speed transmission
