Fault code
Rick Scott 1969
55
Bejoording WA
VY SV8
Hey guys
I’m stuck my 2004 VZ comes up with a powertrain fault so I go to Neighbor code stated oil pressure sensor, I replaced it then go for 5kms drive come up again. Car drove back in limp mode. Turned car off then started straight away and it ran sweet. It’s done this a couple of times in one day. I jacked up the car as I know it’s battery is brand new. Plugs, coil packs, new. I noticed the T piece on the fuel filter broken and the return line hanging could this be my issue as I will replace fuel pump and filter at the same time. I’m an old fella and these electronic cars are a head case. Any thoughts or suggestions
cheers
ORT
krusing
Melbourne, Bayside
depending on the brand of the fuel filter,
I thought the one under the car was a Metal Fuel Filter ?
Or
is their another one ?
krusing
Melbourne, Bayside
Maybe you can use a standard fuel filter,
Possible make up a T-Piece from parts from Supercheap or another auto parts supplier,
I do know they have various brass fittings that are female t-pieces and screw in barbs,
Having a seperate T fitting, you can use a stock filter.
Rick Scott 1969
55
Bejoording WA
VY SV8
I’m going to get a new hose T piece and filter today but could that cause my fault code.
