Fault codes
B.R.K.
47
Tasmania
07commodore vz
Vz crewman v6 2006 hope someone can help with codes fd00and fd40 thanks friends
Fu Manchu
WA.
Slug powered VZ, Cross 8 VZ, VE Calais & ya mum.
Those aren’t codes produced by Holden. How are you collecting the codes?
will be either Pxxxx (P for power train) Bxxxx (B for body) as an example of the two most common code catagories you will get.
B.R.K.
47
Tasmania
07commodore vz
Hi i think the numbers were right relating to emission problems .used volvo scan tool by mistake . .have been cleared will see if they come back. Thanks .
B.R.K.
47
Tasmania
07commodore vz
Ute done 200,000 timing chain a bit ratley is that normal for v6 otherwise goes really well.one owner,general condition really good reasonable service history.
gungazza
65
west suburbs
executive vt 5.0lt VZ CREWMAN
probably worn tensioner or too
B.R.K.
47
Tasmania
07commodore vz
Happens on start up otherwise fine will check parts cost.
Fu Manchu
WA.
Don’t start parts swapping.
B.R.K.
47
Tasmania
07commodore vz
What do you mean by parts swapping?
Fu Manchu
WA.
Don’t think something is faulty and guess, leading to buying a part and replacing it, only to find the fault still exists because there was no actual fault with the part/sensor in the first place.
Then buy another part and try that and so on. Many workshops even do this.
There are ways of sorting through things to get supporting evidence to change a faulty part. Gathering codes, current and historical, is the start. They are the clues that start the investigation.
B.R.K.
47
Tasmania
07commodore vz
Hi friends confirmed timing chain stretched so looking for replacement for my 07 v6
Genuine part from holden $950.00 ebay 235.00 2 yr warranty .. any one had any experiences regards brk.
