Raze96
- May 18, 2021
- 2
- 0
- 1
- Age
- 27
- Location
- New zealand
- VZ holden executive
Hello gentlemen,
Right, problem started off with a broken alternator cable, re crimped it and put it back, problem went away, few months later the crimp failed so we just ran another battery cable from the alternator to the battery and the problem went away..
Couple weeks after I get in my car today after work and dead. Battery dead flat, all the cables looked tight and in place, after a jump it seemed like the alternator was pulling power from the engine and charging the battery but I'm not sure will grab a multi meter tomorrow to confirm.
After letting the car run its diagnostic it was alerting ABS error, and SRS airbag error, and the obd 2 scan came up with this
C0800
Raw code: 4800
ECU: ABS/EBCM/ESC
Status: History DTC
Holden: Device power #1 (low current #1) circuit malfunction; Device Power 1 Circuit Voltage Below Threshold; Device Power 1 Circuit Voltage Above Threshold; Device Power 1 Circuit High Resistance; Control Module Power Circuit High Input
General Electrical Failures
If anyone has a clue on what's going on help
C0800
Raw code: 4800
ECU: ABS/EBCM/ESC
Status: History DTC
