Lachlan3491
- Jan 19, 2022
- 218
- 537
- 93
- Age
- 20
- Location
- NSW
- VS Commodore Ute
Hey lads, just wondering if there are any common faults or maintenance requirements with high mileage cars that I should look into, got a 97 VS Ute with the 3.8 ecotec the kms are unknown the odm stoped working on 223,XXX have had the car for around 8 years and the odm has never worked last records I found if it working through service history was 2009.
these are some of the following I have already replaced or serviced
-Rocker cover gaskets
-Plugs and leads
-swapped in LSD diff around 120,XXX
- all front bushings are Poly
- replaced the whole cooling system
-alternator
- tie rods
- fresh oil in motor, box and diff
- auto filter
- resealed fuel pump due to leak
Side note
-will be replacing the intake valley gasket soon
-service history is hard to track between 2009 and 2014ish
- I service the car very regularly
-Plugs and leads
-alternator
- tie rods
- auto filter
Side note
