faulty fuel gauge
SWE11L
VS Berlina/ KJ Verada/ 88 Trans Am
sorry if this has been a topic before but my fuel indicator has just stopped moving when i satrt up the car until i flick the instrument cluster then it moves to where it should be.... has anyone had this prob? an can tell me how much it cost to fix??
tsalad
VR family truckster
yep same issue now and then.
Whack the dash to get it going.
There is an article in the VN section that outlines the issue - seems to be more prelevant in the VN- its an issue that is fixed with soldering. I havent done it but I assume its the same for the VR/VS
Hytes
Townsville, North Queensland
www.myspace.com
VS Berlina S1
Good ol' hit on top of the dash does it for me. Had this problem for a while, find it helps if i keep my fuel level above the quarter full mark, doesn't seem to do it as often. Now it's just something i put up with.
J_D
Ipswich. QLD
VN S1 and VS V8 Statesman
It can be something as simple as the needles sticking to the pins that they rest on. I had to whack mine to get them going and took the front off and noticed the needles were actually sticking to the pins so I cleaned the pins and havent had a problem since.
Immortality
Staff member
Sth Auck, NZ
common holden problem, normally means the removal of the instrument cluster and re-soldering the joints on the back of the gauge. have alook throught VN-VP section for an "How-to"
edit: this is commonly reffered to as the Holden handshake (slapping the dash after starting the car etc)
