Favour from someone with multimeter and climate control
Tasmaniak
Not a valid input....
S.E. Melbourne
www.ranjinstallations.com.au
Hey guys, last night my fan motor keeled over and died. I have nothing on an setting. When I check for voltage at the fan itself there is voltage present and it goes up and down as I adjust the fan speed... but, it never goes above 8.xx Vdc. so between High and Max there is no change.
Can someone with a multimeter and climate control verify that for me please? It's the two wire plug with a HD red and yellow wire in it and can be unplugged without removing anything from the dash.
If it could be measured between the two wires that would be awesome.
accentstencil
69
Eschol Park, Sydney
WH II Caprice, 5.7 2018 Equinox LTZ V
Where exactly is this plug. I'm a bit confused.
Tasmaniak
S.E. Melbourne
oh ****. nevermind folks. I figured it out myself and disassembled my blower motor, repaired it and reassembled it plus the car.
Interesting to note, High MAX is only available when the engine is running.
showbags
SENIOR EL'BAGO
VT Calais, BMW 135 m sport
Did you have a senior moment tas?
Tasmaniak
S.E. Melbourne
My lips are sealed.....
Tasmaniak
S.E. Melbourne
Nut Kracker
Donating Member
61
Echuca Vic.
VT SS 304ci (195i)
That's OK Tas.
I had a moment on that other thread about removing the door trim to access the electric window motor.
