Fe2 suspension vz sv6 04
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by neilsv6, Apr 27, 2013.
  1. neilsv6
    neilsv6 New Member
    vz sv6 04
    Hey guys,
    My front and rear shocks are at that time to need replacing and I want to lower my car low enough to look good not scrap as my driveway is pretty steep.
    How low will the fe2 sit from wheel arch to ground?
    Any picture would be great to
  2. d.k.vmatt
    d.k.vmatt New Member
    Perth ,W.A
    '06 VZ SS
    Fe2 should be what you already have if your car is an SV6.
  3. aaronevolution
    aaronevolution Donating Member
    Hastings, Victoria
    TURISMO VZ SS 6.0
    Exactly what I was thinking
  4. neilsv6
    neilsv6 New Member
    vz sv6 04
    I checked part number on my springs and called Holden and they said that there stock standard not fe2 and my car is a sv6
  5. Hrd455
    Hrd455 New Member
    Vz v6 ute
    Just get some king spring lows, it drops the car by 1 inch
  6. aaronevolution
    Hastings, Victoria
    TURISMO VZ SS 6.0
    Holden thought the colour of my car was Impulse, they are useless. Check the build plate under the bonnet.
  7. WazzaVN
    WazzaVN Wazza VN
    VZ 6ltr ute, VP Calais and HJ Prem
    Fe2 sits a bit high in my opinion. Lows in front and sl's in the rear would look ok and still be fairly practical. And legal as long as you don't get an exhaust that hangs down low.
  8. neilsv6
    neilsv6 New Member
    vz sv6 04
    Would lows in front and sl's in rear look good with 18's? And for shocks and struts what would be a good brand kyb, monroes, pedders?
  9. WazzaVN
    WazzaVN Wazza VN
    You'll pay allot more for peddlers. There's an eBay store called archem suspension who sell king springs with Monroe shocks for about $600. Sl will look ok with 18's. Should drop the rear about 30mm lower than the picture (fe2). Sl will keep it legal too. SSL on 18's might just be under.
  10. neilsv6
    neilsv6 New Member
    vz sv6 04
    Just took my measurements from my lowest point of my car on my driveway if I lower 30mm she will scrape so only solution just keep springs and only change shocks and struts.
    Also turns out my build plate states I have fe2 suspension :)
  11. WazzaVN
    WazzaVN Wazza VN
    Sure you don't even want to get just lows for the rear? They sit so high at the arse lol!
  12. neilsv6
    neilsv6 New Member
    vz sv6 04
    Sounds tempting mate how low will she sit in the rear?
    Just worried about my driveway
  13. HoldenMan7
    HoldenMan7 Member
    WA
    VZ SS 6 SPEED MANUAL
    i think lows will drop it about another 1cm
  14. Krilnik
    Krilnik New Member
    melb
    VS Executive S2
    King Lows and FE2 are exactly the same height.
  15. VS-S
    Ah just get airbags and be done with it.
  16. mattathm
    mattathm Member
    NZ
    VT SS
    Check the data plate under the bonnet, under suspension it should day Fe2.
    Kings springs will be the way to go tho if you already have Fe2 and want lower.
