few questions????????
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by zegerman, Dec 22, 2005.
  1. zegerman
    zegerman New Member
    Brisbane/ Gold Coast
    VS S1 Executive MANUAL
    Hey boys i got a manual VS and when im drivin up to about 80 and slowin down i can feel a bit of a vibration when resting my hand on the stick...... for you blokes that have a manual, what does yours do???? is it normal? Also when i go to start it.... the crank is real slow then it will go.. i put the charger on the battery and it says its fine.... What could be makin it crank so slow? Then i was drivin it today and stalled it....... :embarrass ........ went to start it... and there was nothin there.... i sat for a few seconds took out the clutch put it in neutral and it struggled but started??? does anyone have any ideas what is goin on? is it just a crap battery??? i just bought it soooo i dunno :confused:
  2. Boonz
    Boonz Donating Member
    berri, south australia
    green 355 VG ute
    dunno about the gears but your starter motor is gettin tired and probably needs replacing
  3. fitzy2005
    fitzy2005 New Member
    Wide Bay, Queensland
    VY S2 Berlina
    gearbox mount most likely, and its prolly the alternator or starter motor like previously said
  4. fitzy2005
    VY S2 Berlina
    i good investment is a gregories manual :p very handy
  5. zegerman
    zegerman New Member
    how much for a starter motor?
  6. Boonz
    green 355 VG ute
    powermax is about $140ish and bosch is a little more expensive
  7. Boonz
    green 355 VG ute
    could also just be the brushes which you can do yourself
  8. zegerman
    zegerman New Member
    yer could be..... on the weekend i'll do some battery tests then if that isnt it i'll check power flow to the starter... and if thats ok i'll just put a new starter in.... $$$$$$$ ive had the car 4 days and already spent $300 on fuses and crap.... whoda thought owning a car wood cost so much????
  9. Fekason
    Fekason Fekason
    Penrith NSW
    I've had my VS S2 manual V6 for 8 1/2 years. Passed the $300 in non-scheduled maintenance costs earlier this year, i.e. took 8 years to spend $300.
    I would be inclined to think the battery was getting on. Did you test it under load? Sometimes they look great on low load test, but it only takes one dicky cell and they fall apart on a test under load.
    There is always a small vibration in the gear lever, but if it is more than that, I would expect the problem to be in the drive train or gearbox mounts.
  10. zegerman
    zegerman New Member
    yer i did all the tests on the battery today and it turns out that the earth lead connected to the engine was loose! Ive finally got the car all working and it sooooo awesome to drive! i love it!!!
