few questions
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by reggie_c2005, Aug 31, 2007.
  1. reggie_c2005
    reggie_c2005 New Member
    1997 vs 2 clubsport
    hey guys just a few queries on my vp series 2:
    1. my interior roof is sagging big time what is the best way to fix it?
    2. i recently was canaried for cut springs. i wanna get some king springs. should i go low or super low? as long as its legal lol
    3. my auto is slipping if it happens to **** itself how much would i be up for? thinkin a stage 2 shift kit.
    any help at all would b much appreciated thanks. cheers
  2. 1991_Vn2nV
    1991_Vn2nV New Member
    Gumeracha, Adelaide Hills
    91 VN Berlina & 03 VY Berlina
    2.) Good! No more cut springs... Go superlows.
  3. Morton
    Morton For external use only
    Fairstar the Funship
    Best way to fix the roof, is to remove the entire lining. It's a bit of a pain in the arse, but once it's out you can peel off the material, and glue on some new material of your choice.
    And the auto... well, you're looking at quite a bit of money if you pay someone else to do everything. Stage 2 shift kits will set you back around $400 installed with a 1/2 servo piston, and will only make a slipping gearbox fail sooner - so you're looking at just dropping an entire 2nd hand transmission in and getting that kitted. Rebuilds are expensive :)
  4. azkwazere
    azkwazere Ahhh Yes, Ahhh Yes....
    .....SE Burbs
    VP 5-SPD / 24-SPD Racer Hybrid
    superows are illegal, mine wouldnt pass a road with supers as the K frame was way too low... thats on stockies, 18's sit it legal.
    Pull The whole lining out and use spray on contact adhesive to restick the roof lining, do it in halfs as youll sun out of time(re drying) to do the whoe thing at once.
    Threres a how to around here some where.
    Auto, itll cost anywhere from $700 to $2000 for auto rebuilds depending on what you have done.
    Another auto can be sourced fro the $350mark.
    aZk.
  5. Emackulation
    Emackulation Banned
    SE Queensland
    '92 HSV VP GTS
    Can vouch for that. I got a stage 1 shift kit (only because they woudn't warrant a stage 2 or 3) corvette servo and full rebuild (inc torque converter) I also had a heavy duty drive shell fitted and a transmission cooler. Total $2600. IMO I think I got a good deal, all was done in 4 or so days.
  6. 1991_Vn2nV
    Hmm interesting. I have ultralow fronts and superlow rears and im sitting legal.
