This panel goes in with the whole HVAC system in one go during assembly.
In VF, the same panel is made from a high density plastic, however it is a totally different shape to the VE. This to me, suggests Holden were well and truly aware of this issue.
I think every VE owner should get in there and check behind the insulation.
It was when I had to remove the accelerator while removing the instrument pad assembly that I discovered mine. Finger went right through the rust. The pedal was loose from the plate, if not from a few mm of metal still hanging in there.
This rust can not be fixed or patched with it remaining in the car.
I had to treat the firewall for surface rust (due to the rust from the pedal plate) and do some respraying in that area.
I suspect that it was a few things coming together with this.
1. Leaking heater hoses (replaced with updated part number).
2. Insulation panels leaching the seeping coolant through onto the pedal plate.
3. Poor welds on studs and brackets welded to the pedal plate. Welds go through the metal and create weak spots prone to the rust.
The panel is sealed with an unusual expanded foam rather than a sealant.
This comes applied to the panel when new.
If that foam was available in a tube or applicator, then I’d suggest having that plate electroplated before installing.
Maybe someone could cad design a 3D printed plastic replacement?
I chose not to reinstall firewall insulation behind the brake booster and over the pedal plate. Instead I made a foam sound insulation panel for the inside of the car. To go behind the factory one that hides most of this rust.
In hindsight, I would have made another to go the whole way along the firewall inside behind the factory sound insulation as well.
