`Hi all,
Picking up my first new car, a VF Calais today.
Any tips on how to drive for the first while?
I have just assumed I should take it easy for the first 1000km or so?
+1 what Reaper stated.
do not drive at any one constant speed
`Hi all,
Definitely run the car in gently.
-- go easy on it for the first 3 - 4000 kms. No hard acceleration and high RPM. The car has heaps of power and torque so there is no reason to push it hard to get all the performance you need for sensible driving around town and on the highway.
- as reaper said, get it out on the highway as much as possible and vary the speed up and down between 70 and the top speed limit. Never sit for lengthy periods at the same speed while you are running it in. Around town just drive gently and traffic usually requires that you never sit on the same speed for very long in any event.
Keep an eye on all your fluid levels - engine oil, coolant, brake fluid to ensure everything is normal. These need to be checked on a regular basis in any event as part of normal maintenance. Buy some of the correct spec engine oil for top ups as you are going to need to top up the oil a little between services in any event - depending on how frequently you change the engine oil. Buy some coolant concentrate from Holden spares so you have fluid on hand to top up coolant as needed (it needs to be mixed 50/50 with demineralised water).
Have the engine oil and filter changed at about the 1-2000 km amrk. This will clean out any fine debris in the engine left from the manufacturing process. If you do not then ensure you have it done at the first service (3000km ). Holden does NOT include an oil and filter change on the first service (3000 km) so if not done by you before hand you will have to ask for it to be done. Otherwise the oil will not be touched until the next service.
Finally do not leave the engine oil and filter changes to the 15000 km intervals in the service book (which I assume Holden is still using for the VF). After the very first change, have the engine oil and filter changed thereafter at least every 7500 kms and only use the oils specified by GM for your engine (owners' manual). This is cheap preventative maintenance for your expensive new car investment, ensures there is minimal damaging sludge build up in your engine, optimises engine lubrication and reduces engine wear (bearings, cylinders , piston rings etc etc etc).
