rocknroll93
- Jun 14, 2012
- 4
- 0
- 0
- Age
- 31
- Location
- Pakenham VIC
- VP commodore, Series 1, 3.8ltr V6
Hey all, first post here, and I have a few questions for you regarding my VP commodore.
it's sedan, the 5ltr V6, series 1 I believe, but most of that is unimportant to my questions.
the first question I have should be simple..
what is the stock exhaust diameter? I've done a fair bit of searching, and only find aftermarket parts dimensions.. I just want to know how big the stock is before I decide on aftermarket parts.
2nd question: how hard will it be to put a VS interior into a VP? I want A VP dash, console and door trim. will I have to swap the computer for a VS one to accommodate for the tachometer, or is there more involved, and how do I relocate the heating vents from the stock VP dash to the VS door vents?
3rd question: I Need various bushes in the VP, as alot of them are perished. Should I just go Nolathane all around?
4th question (may be a little tricky for me to explain): there was a miss in the car a couple of days ago, since then, we (me neighbor as well, as he is a qualified mechanic) have mostly fixed it, as alot of it was caused by old/grotty fuel. we replaced the fuel filter as it was full of crap, and have put a bottle of Injector cleaner in with the fuel. that has removed most off this 'miss' but we aren't too sure that it's even a cylinder miss, and it may be something else. it doesn't miss on idle, and only as you accelerate from 1st gear to 2nd. it also seems like it misses as you hold your foot on the accelerator keeping a speed of around 60kms. I know there is a wheel bearing that need replacing, but this feels like a miss more that the bearing. you can feel the bearing, but it feels different to this miss. there was a hole in the rear muffler until today, and that wasn't the cause of this problem. it's none of the coils, and im pretty sure none of the leads or plugs are the problem too. it feels like a miss, but it may not be. the car just may need a good tune..
hope you understood the last one, and im looking forward to hang out on here a bit more.
remember, I don't have a solid income, and there are questions for when I finally get a job/my P's.
I just figured I would ask now, as I can do little bits here and there. the past 2 days I have done the fuel filter, radiator, welded up a hole in the rear muffler, fixed my tail lights, and removed most of a miss.
I want to get this car to a decent running conditon before I get it to show condition, and I already have plans for that.
hope someone (or a few of you) can answer my questions, and I hope to be able to show off my car on here when I get a job!
Cheers,
-John
(sorry for the massive post)
Cheers,
-John
