hey all, i recently got a vn ss kit and its painted now. im in the process of fitting the sideskirts now. basically i heard stickaflex was the glue to use so i got some of that. i wanna know whats the best way to fit them?? as im not to sure on it all. cheers
squirt a blob of it every few inches down along it push up onto the car and then screw in from the ends into the wheel arches, that how drifters do it or genrally a factory side skirt will have holes drilled in along the sill panel and the inside of the skirt will have clips which will clip into the holes holding it there and then 2 or 3 screws at each end in the wheel arches your choice how you do it. urethane is very stong and should hold no probs just will take 24 hours to dry. so taping it up in place is a mist to stop it from falling off
