its easy as just make sure you have the drive shaft that matches as the vt has universal joints and vx on wards has rubber mounts , so thats the only thing to look out for and you mite need a few high tennsile bolts that fit but its easy as .
just loosen the bolts at the diff from the drive shaft , drop the drive shaft loop , undo all bolts from drive shaft and take drive shaft away.
then take out the bolts from either side of the diff that go to the wheels , there is a little plug on both sides for the abs sensors ( or something else maybe but i think its the abs ).
then there is 4 big bolts holding the diff up so undo them ( depending on how u are doing it you need to have something stacked under it to hold the weight , makes it easier ) , And then once that is done and its dropping there is a little hose on the breather tube from the diff just slide that of and done .
do backwards to put new one in ( go buy $300 worth of tools etc if need be and if your not sure take pictures with a digital camera as you go so you know were everything goes . lots cheaper than $1000 and you will feel great driving it around knowing you installed it )
