So there is no clearance issues, cause pacemaker and genie both advertise that they only fit with powersteering rack.
Pacies will only fit manual rack setups & later vn-vs crossmember + power rack.
It's early vb-k powersteer/crossmember setups that have several issues.Where pipes curve away from sump it touches. top of power rack
Sounds like VR V6 Pacies, mine has no more than 7-8mm clearance. Had to unbolt rack at the mounting points and move it to fit them. IIRC I think I also had to undo the right TRE to get enough drop.It's early vb-k powersteer/crossmember setups that have several issues.Where pipes curve away from sump it touches. top of power rack
Hey sorry to jump on thread but you seem to know what your talking about! I have a vk with 304 stroker, has factory vk k frame and vh manual steer/shaft what headers would fit? Pacemakers? Thanks bruvVl-n was when steering rack mounting points changed along with more compact power racks with better exhaust clearance.
Can say for certain vh & vk it's all interchangeable...only visual difference with manual intermediate shafts.
I've had vk crossmember + manual rack in vp ute...don't have manual intermediate yet to see it intermediate shaft uni's will allow to mix n match of parts.
