Fitting Manifold Spacer. OEM 'shim' ?
Commo Baba
VX II Acclaim Wagon.
I am fitting a MACE 12mm Manifold Insulator to my VX series2 V6.
I have got down to the point of pulling up the plenum. What I find there between plenum and runners is a factory metal shim /spacer/ gasket ?
This does not appear in the MACE instructions at all.
Do I remove this or what ?
Sent a mail direct to Mace this morning but haven't heard back yet. At this rate it won't be going back together today.
MACE
Hi Commo Baba,
Thank you for your enquiry:
Please discard/remove that steel that gasket.
My sincerest apologies for this delay. Hopefully you're able to finish the job off today and enjoy the upgrade.
If you have any questions please don't hesitate to ask
Kindest Regards,
Steve
Commo Baba
Thanks Steve. That's what I thought but wanted to make sure.
Won't be able to finish today due to poor health. (Hope a rat doesn't jump down a runner overnight )
Sure I will appreciate the upgrade next time I'm out. The others (CAI & PCM) have worked step by step.
commodore665
expat Saffa
54
New Zealand via Cape Town
2005 SV6 & Alfa Romeo 156 V6
Just a tip , don't know whether you'll see this , but cover the runners until you finish the job , in case something does drop down there .
Commo Baba
Thanks, I did just go and do that. Put some clean cloth doubled over and lowered the plenum onto it.
commodore665
expat Saffa
54
that'll do it , I think you'll like the insulators , I installed them on my VX and have the 25mm ones on my VZ as well .
MACE
"Thanks Steve. That's what I thought but wanted to make sure."
No problem.
"Won't be able to finish today due to poor health. (Hope a rat doesn't jump down a runner overnight)"
Hope you get well soon and get it done easily.
"Sure, I will appreciate the upgrade next time I'm out. The others (CAI & PCM) have worked step by step."
All good.
If you have any other questions, please do not hesitate to ask.
Kindest Regards,
Damo
