lastlegend
Phantom VY SS
- Sep 3, 2008
- 182
- 3
- 0
- Location
- Thorneside QLD
- 2003 Black VY SS + 1999 Silver VT Olympic Sedan
How you going mate... first up... any type of space or adapter is a big no-no... they illegal and in alot of cases fairly dangerous when you get the dodge ones.
Right... back to your main issue...
My understanding is that, the VE and the VY DO share the same stud pattern (5x120) but they do not share the centre bore or studs.
I know that the 12mm stud was used on the VY while the VE has a 14mm stud. So you need to be careful with the nuts you use.
Found this also:
Holden VE Commodore: production line at the Elizabeth factory in Adelaide.
When Holden introduced the all-new VE Commodore in August it changed some crucial dimensions of the wheel-locating system. This was done to avoid confusion on the production line (as the Holden factory will be building both new and old models for some time yet) and to cope with the new Commodore's extra weight, width and grip levels.
Holden sent the following statement to Drive on Wednesday: "Fitting VE wheels onto a VZ [or earlier model Commodore] is not recommended or condoned by GM Holden as it raises some safety concerns as there are two major differences in the wheels."
Holden said the VE Commodore has 14mm wheel studs and earlier Commodores have 12mm wheel studs.
"If a VE wheel were fitted onto a VZ [or earlier model Commodore] there is a concern that there would not be enough bearing area under the retention nut on the aluminium wheel, which, worse case scenario, means the wheel could potentially fall off."
And also this thread:
http://forums.justcommodores.com.au/general/64226-vz-vs-ve-offset.html
Hope that helps.
Quick question?.......can you change the wheel studs on a VYSS Hub from 12mm to 14mm so that you don't have to machine the rims?
