fitting vt blinkers?
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by VRV6BT1, Jul 31, 2008.
  1. VRV6BT1
    VRV6BT1 New Member
    telarah
    S1 VR V6 BT1
    I've done a search and can't find anything.
    Does anyone know an easier way of fitting them than taking the inner guard out?
  2. Dan VS 231
    Dan VS 231 New Member
    Perth W.A.
    VZ Senator
    If they are the oval shaped ones from Holden then will be 2 little dag like things on the underside of the indicator that prevents them from clipping in to the original rectangle hole in the guard. You will need to shave these dags down and they will click right in.
    I have them on my VS and after clipping off those dags and installing them they are in there strongly and havent moved in hundreds of k's so far. Hope this helps, we had to do some thinking to get them in as well and it worked for my ride.
  3. Grennan
    Glen Waverley, Victoria
    VE SSV G8 Sportswagon
  4. shanhsv
    shanhsv Luvo
    Muswellbrook, NSW
    VSII Calais V6 & VSII Senator 215i
    Not sure why you need to shave anything off,they fit nice and snug straight up.the loop bit goes in first,theres a small gap between the loop and back of the blinker which fits onto the guard,from there the rest can be pushed in
  5. 5 speed VR
    5 speed VR Green Machine
    Sunny Coast QLD
    Vr V6 Exc 5 spd
    As Shanhsv said they do fit in nice and easy as i did it on the weekend myself to my vr, although i had to put them in back to front to the ones i pulled out (so the piece where the wire plug is angles to the back of the car and not the front) Hope this helps
  6. Summer-Sickness
    Summer-Sickness 2005 VZ EXEC
    Rockingham, Perth
    05 VZ Executive
    mine just clicked straight in when i did it to my old vr...
