Fitting VZ front suspension into VXII
H
harrop.senator
Guest
Fronts are 180-230 lbs/inch
Rears 360-440 lbs/inch
Couldn't find the fe2 to compare.
I can't find the away bar sizes for a vz sv6 if your V8 is an ss it should have a 27mm front. 16mm rear.
The hsv fronts are a 28mm and so is the vz Monaro. Price of those probably more then an aftermarket sway bar though.
Vt V8 fe2 is 17mm so can be a cheap upgrade if you can find one.
Sorry I wasn't that helpful , without the vz sway bar sizes and the fe2 spring rates it's hard to do a good comparison.
MiKExAUS
Sydney NSW
VX SS A4 Series II
Not at all. Appreciate sharing your data. Thank you. Surprised they went backwards with vx2 rear swaybar? As in from 17 to 16mm
H
harrop.senator
Guest
H
harrop.senator
Guest
I'd say it was to counteract the boat anchor 5 litres tendency to understeer.
