Fixable?
Adrian's Vr
22
Vr commodore manual
Pressed the brakes by accident not knowing that caliber was disconnected, can i just open the fluid line and push it back it or she cactus?
vr304
Auckland, New Zealand
2007 ssv manual
Can just be pushed back in mate just make sure you give it a wipe 1st so u don’t push any crap back in with it and wreck the seals
Adrian's Vr
22
Vr commodore manual
Do i undo the hose before i push it in?
_R_J_K_
Zenki S14
No, just push it back in.
vs-lover
VS S2 Calais, VS S2 Exec Wagon, VS S2 Acclaim
The bleeder nipple must be opened as you'll never be able to push it in by hand against the air that's trapped behind the piston that you've had pop out. Once the piston is in full contact all around with the internal seal you've created a sealed system again, thus pushing by hand is impossible. Opening the bleeder will allow the trapped air to escape.
After this situation you will have to bleed the system to remove the air and have fluid take up all the space inside the calliper.
woteva
NEED 4 SPEED
Adelaide S.A.
losh1971
North Tas
VE Series I SS Ute
Take it right out and scrub it with a scourer and some brake cleaner. Then wash out the inside of the caliper with brake cleaner. Put some brake fluid on the seal or a tiny bit of rubber grease. With the nipple cracked it should go back in by hand.
Adrian's Vr
22
Vr commodore manual
Nah
I took the bleeder nipple off and it still doesn't wanna budge
losh1971
North Tas
VE Series I SS Ute
You might need to remove the caliper completely and work on it on your bench. Sometimes the dust seal comes out and prevents the piston from going back in.
