vs-lover
- Mar 9, 2013
- 2,644
- 1,812
- 113
- Location
- Adelaide
- VS S2 Calais, VS S2 Exec Wagon, VS S2 Acclaim
It'll push back in just fine, the fluid will just be returned to the res.
Yes but not but hand without the bleeder open. For this situation you'll require a clamp to push it backwards and also push fluid at the same time. Only with the system "open" will you be able to push by hand.
Also while we are here on this topic. I can not agree with using rubber grease on any brakes parts or seals. Every credible workshop / Service Manual will tell you to use clean fresh brake fluid as a lubricant during assembly. Grease of any type is considered as a contaminant and should not be used.
