Hi all. I have a vz ss it is pretty stock I am keen to do some upgrades just wonder is it worth getting a flash tune done on it or just go the OTR and a mafless tune thanks.
Work out what you want work out what you can afford work out every thing you are doing and get it all together and fit it up together then tune it as it will need a tune with each mod you do
Best value for money would be to go the OTR and mafless tune, gain between 10-25rwkw depending on how low the current stock tune is set. Going for a std maf style tune will gain a small amount in comparison to the above.
Pretty sure they're the same same. just stick with the otr+mafless. its a good starting point for future mods
