flashing mode light
super_6
2000 VT Executive S2
prolly not a problem but when i drove my vt 2day i noticed the red immobiliser light above the mode button was flashing flat out and irratically when i pulled over n restarted the car it stopped flashing, any1 seen this happen b4?
EXCESSV
40
Perth, WA
VE SSV
yeah had this problem with my vt....3 times in 3 years so didnt worry about it and now that its sold...pppffffttt not my problem anymore.
the radiator fans used to go flat out at the same time. do yours???
nsw
falcon
mine also did this and i found it does it when water is low also
maybe its a warning light i dunno
my book doesnt say anything about it
Doctor Bob
Grandpa
Retired
RG. Colorado & Caravan
this is a sign that there is a problem with the communications in the car, could be a few things at fault, you would need to read the codes with a good scantool, not a generic thing that cannot interperet the manufacturer specific codes. This should point you in the right direction regarding where the fault lies.
Cheers Rob
X
xu1au
Guest
mine has done it 2 times in 6 months but doesnt seem to be much of a problem,,turn ignition off then restart and workes fine then..
Lord-Data
44
Newcastle, NSW
www.VIDGuide.com
Impulse Blue VE SV6
Happened to me the other day .. Kinda wondering if maybe it wasnt the first time, as very occasionally, the key fails to start the car ... ie, turns and turns and turns, but no start. As soon as you turn the key to off, then try to start again, works perfectly. the light is supposed to be the light it signals alarm/imob state, so perhaps linked .. Had any problems starting lately?
1710hayden
Berkeley vale
Vt executive series 2 manual
I have the same problem with my manual vt everything is toped up and always maintained but sometimes when i start it the dash beeps and the airbag light comes on and my fans go flat out and the mode light flashes? Still haven't figured it out
IBLOWN
45
VS V6 TT/'13 VF Senator/'11 WM CapriceV/Hayabusa
That sounds like an ABS module problem. Does you A/C work?
