why is it bad to take off the negative first?
so would it be possible for the amp to blow due to someone doing welding on my car?
no
it is pysicaly impossible for that to happen. goes against all laws of physics. i can tell you teh following
when you get a batter, it has a cca ratting, cold cranking amps ratting, this is how much the battery can produce for a period of time to start the car when cold. (usualy a tiem frame of 5 to 10 minutes.)
when you drive your car under normal conditions. i.e. say going down to the shops and back you car for example will use 40 to 50 amps from the battery to keep all systems running in your car, all sensors, brakeing bits, fuel pump, guages, all the stuff you can think off.
you remove yoru normal little radio and replace that with a monster and put a 1200 watt amp and sub in the boot. now, this is where it gets nasty. you are now drawing 70 to 80 amps from the batter, however due to restrictions placed on your alternator (electrical principles 3 and 4) your battery is now no-longer able to suply the demand needed by your car.
to sum it up.
stock alternator. 60-70 amps.
new radio and all other bits still there 80-90 amps
difference in current 10-20 amps
effect, battery goes flat and headlights will dip as alternator reaches saturation point (there point where it is un-able to produce anymore current)
sollution is replace alternator. and put a bigger battery in there also
or run a 2nd alternator in parralell with your current one, producing same voltage, 2wice the current. (will need a bigger battery)
while your at it, you will need a bigger earth wire
hey hows it goin mate wat sort of commy is it. i have a vt running a fusion powerplant 1500watt running two pioneer 15s and a fusion 400watt running my 6x9s and i killed my alternator. i put a 100 amp alternator $300 from repco and just put a standerd brand new battery and it runs beautifull plus running everything in the car the only problem i have is my battery light is till on but i have been told its not due to the system
i have dual 0g runs - hit 140.9 on TL without upgrading battery to chassis. Added 0g batt- to chassis earth - and hit 141?
well ****!no i havent changed the earth cable it didnt realy come to mind? garfa yes my amp is only cea rated to 1600 wrms @ 14.5 volts but on the average 12 volts its arond 600-900 but i actually thought of something today while at work, a few weeks ago i had a set of pacey extractors installed by a well known muffler and exhuast place and they usually take the battery cables off to do the welding and im wondering if the have stuffed my amp by either 1 takeing the earth off the battery first (wich is not good for any car audio) or 2 wether the current from the welder has killed my amp? and you just know if thats the case i have no chance of getting them to fix it let alone prove it:bang: could this be the case?
