Flow of standard injectors?
Discussion in 'General' started by Razor-, Sep 3, 2008.
  1. Razor-
    Razor- New Member
    VS UTE
    hey
    im looken at injectors and was wonderin what the flow rate of the standard ones in a v6 ecotec would be? . . . . . i can only seem to find refurbished ones and not new high flow ones . . . . would injectors be the next step after full exhaust system, coa, k&n filter, high ratio rollers and a mace engenere manifold spacer . . . . or would there be better upgrade as the next step
  2. daron
    daron wizfiz
    adelaide
    VE SSV
    you wont need bigger jectors unless going charger and tune
    your factory computer and jectors will cope with full exhaust system, coa, k&n filter, high ratio rollers and a mace engenere manifold spacer
  3. Razor-
    Razor- New Member
    VS UTE
    uh k thanks . . . . . . a little of topic but how much gain is there replacing the standared pannel with a k&n one? . . . . .what shows more performance increase? filter or cai? how about economy increase
  4. LowVp
    LowVp VP Enthusiast
    Dalby, Qld
    VP Ute 3.8T T56
    fyi stock injectors flow around the 19lb/hr
  5. daron
    daron wizfiz
    adelaide
    VE SSV
    well the old k&n filter is a good debate
    some ppl swear it makes more power some ppl say ts the same and some say they lost power
    personally for the money ya spend on k&n ya can get other brands cheeper and do same or better job
    i think lukey do one and a few other brands
    there are threads for this info ya a search and read
  6. LowVp
    LowVp VP Enthusiast
    Dalby, Qld
    VP Ute 3.8T T56
    i don't think it give you more power on a stock engine just better response
