Fluid leaking under Dashboard in VH
veeque92
41
WH Statesman SeriesII 5.7
Hi all, I have a bit of a strange one here,
Our VH commodore is leaking red fluid under the dashboard. It is all over the wires and stuff in under the steering wheel and not to sure where it could be coming from.
The car doesn't have power steering so it isn't that,
I though maybe brake fluid but that is normally more of a green than a red and I cant think of anywhere where trans fluid could be coming from.
Any help or info would be greatly appreciated.
Goon
Scientific Tuning
BrisVegas. QLD
VY CUSTOM.
Do u have an oil pressure gauge? that may be leaking.
If so try plummer's tape.
85berlina
VK berlina sedan 202
Its probably coolant leaking from the heater core or hoses. Coolant can either be green or red and the red stuff is the generally the more expensive stuff.
Pub247
Melbourne S.E.
Ford Fairmont
No, I know what it is i had the same prob and when i changed my dash i found out it's gearbox oil mine bieng a manual coming out of the speedo cable and leaking down onto my brake pedal take your dash out and have a look at the speedo there was oil all over the back of mine
308vkcalais
DIO..
Adelaide(City of Godbothers)Churches S.A.
308 VK Calais, VK EFI Berlina, V6 VN & Kenworth...
Oil Leak under the Dash
My word this is an unusal one....???Not that I'm an expert on Manual gearboxes but isn't gear box oil a similar colour to engine oil, stinks like a basta*rd & no doubt would lose it's colour quickly being burnt inside the tranny so wouldn't remain it's normal colour.If Gear box oil is being pumped up the speedo cable then there maybe sum internal pressure build up.Do Manual gear boxes have breather holes like diffs....???
SL/ENUT
The SL/E Fanatic!
Burnie, Tasmania
VB SL/E 5L
Well if the manaul geaboxs do have breather holes, i'm yet to see one. Come to think of it they don't. So 308vkcalais might be right, the gearbox is having internal pressure build up and the oil is heading up the speedo cable.
veeque92
41
The car is entirely stock except for its on gas and it is an Automatic,
It looks like clean trans fluid to me but was just confused as to how it could possibly get there,
Its not coolant as we run the green stuff and our brake fluid is green too and it only has the stock oil light which I'm sue would be electric.
Will try and look this weekend. Thanks all for the quick replies.
9C1pack
Yep, it will be auto trans fluid. Smell and feel the stuff under the dash and compare it to the fluid on the trans dip stick, coolant wont feel greasy and will have a different smell, I remember a mate had a manual holden do the same years ago, I dont remember the cure though. Ring a speedometer repair specialist and ask them, It may just be a seal or a new cable.
Didnt overfill the trans did you?
Pub247
Melbourne S.E.
Ford Fairmont
Yeah mine only leaks out when i give it a hiding then slow down and some drips out my gearbox is pretty stuffed was like that when i got it hard to change into 2nd and sometimes grinds but i'm not gonna fix it i only paid 600 for it
Goon
Scientific Tuning
BrisVegas. QLD
VY CUSTOM.
dont grinf your box to much, the teeth will snap and she will keep falling "slipping" out of gear !
It's not nice traveling over 100k then the 5th gear slips in N, not a pretty sound and only seconds before damage can occur.
