Just wondering if anyone can confirm how much transmission fluid I’ll need when doing the camaro deep pan mod.
I’ll be adding a transmission cooler to it at the same time
That’s a great question. Had a similar issue after fitting external engine oil cooler. Everyone said just fill to dipstick markings. Then found a tech bulletin advising 800ml of circuit volume additional needed for the cooler circuit. Same concept for trans pan mod. Maybe compare volume difference between standard and camaro pans. Use water and measure the volume difference?
