Foaming VP -2009 edition
Discussion in 'VN - VP - VG - VQ' started by greenfoam, Feb 10, 2009.
Thread Status:
Not open for further replies.
  1. greenfoam
    greenfoam New Member
    VP Executive R-spec
    FOAMING VP STAGE 2
    Parts to be installed during 2009
    1. Wade 325B1158B12 Camshaft
    2. Rollmaster red timing chain
    3. Speed Pro LT1 Springs
    4. Ported VR Heads 10:1 compression
    5. 27 thou Cometic head gaskets
    6. Cut banana manifold 10 inch runners
    Expected power 210-220 rwkw, Hopefully with this combo will run 12's (it should, just)
    I'll be doing this in several stages so the car is on the road as often as possible. First the valve springs will be installed on the original heads. Hoping to do this sometime this week.
    Camshaft will be installed possibly the following week
    Manifold will be completed as soon as possible (during this month I hope)
    Then Manifold will be tested
    Then the new heads will be machined along with the manifold and installed
    And that's it, even taking into account slacker time it should be all ready to run a time with the re-opening of the drag strip in October/November
    I plan on doing a full detailed picture thread of the entire cam/head/manfold work so I'll update this as it happens
    Simulation data
    Code:
    Engine_RPM     800     1200    1600    2000    2400    2800    3200    3600    4000    4400    4800    5200    5600    6000    6400    6800    7200
    Brk_Tq         220     249     254     260     275     283     297     329     349     354     352     345     329     306     272     235     199
    Brake_HP       33.50   57.0    77.4    99.1    126     151     181     226     265     297     321     341     350     349     332     304     273
    Exh_Pres       0.0     0.0     0.0     0.1     0.1     0.2     0.2     0.4     0.5     0.6     0.8     0.9     1.0     1.1     1.1     1.1     1.1
    Int_Vac        0.0     0.0     0.0     0.0     0.0     0.0     0.0     0.1     0.1     0.1     0.2     0.2     0.2     0.2     0.2     0.2     0.3
    Vol_Eff        62.7    71.4    72.9    72.9    76.9    79.7    83.7    92.3    98.4    101.3   102.7   103.1   100.7   97.8    93.4    88.4    85.0
    Actual_CFM     50.7    78.9    103     128     162     196     236     292     346     392     433     472     496     516     526     529     538
    Fuel_Flow      17.71   27.58   35.85   44.78   56.7    68.6    82.3    102     121     137     151     165     173     180     184     185     188
    Nitrous        0.00    0.00    0.00    0.00    0.00    0.00    0.00    0.00    0.00    0.00    0.00    0.00    0.00    0.00    0.00    0.00    0.00
    Ntrs_Fuel      0.00    0.00    0.00    0.00    0.00    0.00    0.00    0.00    0.00    0.00    0.00    0.00    0.00    0.00    0.00    0.00    0.00
    BMEP           109     124     126     129     136     141     147     163     173     176     174     171     163     152     135     116     98.9
    A/F_Mxtr_Qlty  76.7    84.9    92.4    99.4    100.0   100.0   100.0   100.0   100.0   100.0   100.0   100.0   100.0   100.0   100.0   100.0   100.0
    BSFC           0.529   0.484   0.463   0.452   0.451   0.454   0.455   0.452   0.456   0.461   0.471   0.483   0.495   0.517   0.553   0.608   0.688
    Thermal_Eff    28.14   30.78   32.52   33.68   33.84   33.83   33.92   33.96   33.76   33.55   33.15   32.74   32.49   31.81   30.71   29.26   27.36
    IMEP           121     137     142     146     155     161     169     187     198     203     203     202     195     186     171     154     139
    Frctn_Tq       23.88   27.54   31.26   35.04   38.09   41.20   44.39   47.66   51.0    54.4    57.9    61.4    65.1    68.8    72.6    76.4    80.4
    Frctn_HP       3.64    6.29    9.52    13.34   17.40   21.96   27.05   32.67   38.84   45.58   52.9    60.8    69.4    78.6    88.4    99.0    110
    FMEP           11.85   13.66   15.51   17.38   18.89   20.44   22.02   23.64   25.30   26.99   28.71   30.48   32.28   34.12   36.00   37.91   39.87
    Mech_Eff       90.2    90.1    89.0    88.1    87.8    87.3    87.0    87.4    87.2    86.7    85.9    84.9    83.5    81.6    79.0    75.4    71.3
    Motoring_HP    3.68    6.44    10.44   15.15   20.23   25.69   31.58   38.17   46.77   57.0    69.8    84.7    98.3    114     132     148     164
    Pumpng_Work    -0.04   -0.15   -0.91   -1.80   -2.83   -3.73   -4.53   -5.50   -7.93   -11.39  -16.91  -23.85  -28.95  -35.74  -43.38  -48.82  -53.5
    Residual_Exh   4.6     4.3     7.8     9.0     7.2     6.5     6.8     5.2     3.7     3.2     2.8     2.2     2.1     2.2     2.6     2.9     3.6
    Shrt_Circuit   1.0     0.7     0.0     0.0     0.0     0.0     0.0     0.0     0.0     0.0     0.0     0.1     0.1     0.1     0.1     0.1     0.0
    Exh_Temp       1143    1244    1302    1339    1369    1386    1396    1408    1418    1428    1433    1441    1437    1435    1413    1376    1321
    Mx_Cyl_Pres    718     767     778     793     833     856     902     993     1053    1082    1095    1099    1067    1034    975     908     843
    Mx_Cyl_Tmp     4646    4628    4518    4507    4542    4530    4506    4548    4594    4595    4595    4624    4601    4568    4490    4370    4144
    In_Port_Tmp    155     152     152     150     142     136     131     124     117     115     111     109     106     103     98      98      96
    Piston_Spd     403     605     806     1008    1210    1411    1613    1814    2016    2218    2419    2621    2822    3024    3226    3427    3629
    Piston_Gs_@_TD 30      80      140     220     310     430     560     710     870     1060    1260    1470    1710    1960    2230    2520    2830
    Coolant_HP     28.58   35.93   43.58   52.1    60.5    68.1    76.3    85.2    94.2    104     113     123     131     141     147     152     152
    Blow_By        13.5    14.7    15.2    15.6    16.4    16.9    17.8    19.6    20.6    21.2    21.5    21.5    21.0    20.3    19.4    18.2    17.2
    In_Tun_Pres    0.0     0.0     0.0     0.1     0.2     0.2     0.6     1.7     2.7     3.8     4.4     5.3     5.3     5.5     6.1     5.6     4.4
    Avg_In_Vel     36      54      73      91      109     127     145     163     181     200     218     236     254     272     290     308     327
    Avg_Ex_Vel     36      54      72      89      107     125     143     161     179     197     215     232     250     268     286     304     322
    Mach_#         0.062   0.093   0.124   0.155   0.186   0.217   0.248   0.279   0.311   0.341   0.372   0.403   0.434   0.464   0.483   0.498   0.499
    Act_In_FlowAre 96.4    96.4    96.4    96.4    96.4    96.4    96.4    96.4    96.4    96.5    96.5    96.6    96.7    96.9    99.2    102.3   108.1
    Act_Ex_FlowAre 96.1    96.1    96.1    96.1    96.1    96.1    96.0    96.0    96.0    96.0    96.0    96.2    96.3    96.6    97.6    101.7   98.7
    Valve_Toss     None    None    None    None    None    None    None    None    None    None    None    None    None    None    Int     In&Ex   In&Ex
  2. Boonz
    Boonz Donating Member
    berri, south australia
    green 355 VG ute
    tease.....:dance:
  3. beefcream
    beefcream Lethal LOKKA
    South,Adelaide
    VS SS 5speed (project) VN exec v6 (daily)
    lol im excited :D
  4. 88GreenVN
    88GreenVN Next Exit Left
    Surprise, Arizona
    Dodge Ram Van 1500 5.2 V8
    I see the boot lid will be the first job :)
  5. padrickz88
    padrickz88 Rick =]
    sunshine, melbourne
    VN V6, nothing special
    do a bigger one! lol
  6. Eliminator
    Eliminator New Member
    Maranello red Vn V8 Calais
    change the comming soon to coming soon :)
  7. PaRaDoX
    PaRaDoX Because Racecouch...
    Melbourne, Victoria
    none
    the extra M adds for more excitement,
    cant wait to see pictures foam you sneaky bugger!
  8. PaRaDoX
    Melbourne, Victoria
    none
    you havnt seen SS hunter!
  9. Renno
    Renno Home Of The Shiny Tank
    Defected And In The Shed
    VN Calais 5L
    This should be a good read!
  10. Morton
    Morton For external use only
    Fairstar the Funship
    Exciting times are ahead!!
  11. Bz Kn33z
    Bz Kn33z Active Member
    Mildura
    Black VN V6 Turbo
    Cant wait untill this is in action looking forward to it very much :)
  12. Commydoor
    Commydoor born in the FB era
    Beresfield, NSW.
    Vr Ss Blown
    I wait with bated breath and a hand on my....
  13. Morton
    oooh my, I wonder where this is going ^_^
  14. azkwazere
    azkwazere Ahhh Yes, Ahhh Yes....
    .....SE Burbs
    VP 5-SPD / 24-SPD Racer Hybrid
    lol... i dont want to wonder...
    aZk.
  15. Commydoor
    Beresfield, NSW.
    Vr Ss Blown
    cheque book?
  16. savage1987
    savage1987 Donating Member
    **eagerly waits with the crowd**
  17. levymetal
    levymetal TURN MY HEADPHONES UP
    Somerville, Victoria
    HSV ENHANCED VP CALAIS
    how much do you think this will cost you all up?
  18. Leebo
    Leebo New Member
    89 VN
    Wheres you house i want to come and have a pick at the money tree lol
  19. greenfoam
    VP Executive R-spec
    About a grand in parts and 500 to have the machining done on the heads, I allready have all the parts
  20. calaiscruzer
    calaiscruzer I drink beer, and I vote!
    VIC
    Atlas Grey VN SS
    And the secret details have been posted!!
    Good to hear ur finishing the manifold.
    Once you get sick of this setup in a year or so, you gota go for a turbo setup...
Thread Status:
