fog light plug on wiring harness
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by shanhsv, Jan 30, 2008.
  1. shanhsv
    shanhsv Luvo
    Muswellbrook, NSW
    VSII Calais V6 & VSII Senator 215i
    Just bought a new foglight switch and i was hoping someone can tell me,does the plug on the wiring harness come out and into the back of the switch or should i have an extra bit the goes to the harness from the switch
  2. markovr
    markovr Well-Known Member
    northside brisbane
    07vessv 94vr .04vz wgn,93vp wgn,82 vhV6 wgn 88 vn
    It uses a plug like the one on your air con switch...stato dash looms (maybe berilnas)will have the plug wired and just spare behind the headlight switch in to the dash loom but exects and most vr/s wont and you will have to wire it in.
  3. shanhsv
    shanhsv Luvo
    Muswellbrook, NSW
    good'o,i know the plug is there i just wasnt sure if it came away from the harness or not and im sure the car is wired up for it coz the plugs for the fog lights are above the head lights and the relay under the bonnet has the wires there.
