Fog Light switch for neons VT
DARGAN
98 VT Commodore
Hi, I was wondering if I could hook the standard holden fog light switch in my car to neons in the footwells somehow, i dont know anything about electrical wiring etc. But yeah I want to hook it up so that the fog light switch turns the neons on/off. I'm trying to avoid putting in some dodge looking after market switch.
thanks, Paul.
accentstencil
71
Caboolture South, QLD
WH II Caprice, 5.7 2018 Equinox LTZ V
If you use the standard fog light switch as it is, your headlights will turn off when your turn the fog light switch on. You would have to do some rewiring. It would be easier to install a toggle type switch.
Bubbaj247
VTR247
VICTORIA
VT ACCLAIM II
Ya should hook it up to ya door pins, so when u open ya door it will go on, also have it on a switch so ya can turn it on while in the car, send me a message if you want the wiring diagram for this, its real easy stuff, cheers
Hairy Eater
Banned
46
Queensland
2000 VX Executive V6
i seen in here somewhere ... think it applies to all states but dont quote me ... i know for sure that it applies to 1 state .. neons have to be connected to the handbrake switch ... Dept Of Transport wants to sure that the neons arent on when your driving ... but with my VX the handbrake lights comes on much sooner than the brakes itself ..... so its not really a fool proof system ...
wrx884
WA's ASR Rep
39
VT Exec/ VT L67 Spac, 5L VP Calais, 77 TC Gemini
U'd b able 2 do it if u dont have the switch hooked up 2 fog lights and only use it 4 the neons all u have 2 do is find the positive and negative pins they will b 4 ur neons then tap into the pos pin with a 12V consistant power mite b best 2 use the 1 from the cig lighter/12V output.
Troyziee
MY17 SSV-R Sportwagon
iv got all my neons and LED lights hooked up to my parkers, so as soon as i switch my parkers or headlights on they all cum on,
its piss easy to do, jus gota find tha wires tha go 2 tha lights and hack in2 em,
it was easy for me cause its all in tha boot, so i just used tha taillight looms, but all u gota do is look at ur lights and figure out which wire does wat, then put ur pos n neg in2 tha wiring accordinly
minux
2017 SSV Redline
I proved quite a while back that in Qld, NSW and Vic neons can be legally used while driving :) There is no law stating otherwise, providing you follow set guidelines.
VTPREDATOR
37
Warwick
VE SS SPORTSWAGON
rito....................................... HOW?
minux
2017 SSV Redline
sno
NSW
VXII SS
where I am your aloud to hav neons while driving if the actual neon is not visible.. only the glow - western australia law
