Fog Lights
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by LUMINA ANIMUL, Mar 17, 2007.
  1. LUMINA ANIMUL
    LUMINA ANIMUL New Member
    VX LUMINA S1
    G'day. does any1 know what extra items I would need 2 instal fog lights onto my vx s? I havnt purchased the fog lights but will very soon. Is there any any extra wiring involved, swithces or are they a simple bolt on item etc etc. any help would be great. Cheers Andrew
  2. Lloyd1986
    Lloyd1986 New Member
    VX II Supercharged S pack
    All the wiring is there, all you need are the fog lights, a switch, and a relay. Plug all that up and they should work. You might also need a light for the dash and you will need to put a hole in the dash for the switch.
  3. CMA
    CMA New Member
    VZ SV6
    How do the lights actually fit into the front bumper? Is it a couple of screws holding them in? And how long r the wires running from the lights?
    Cheers in advance
  4. Jesterarts
    2010 Nissan X-Trail ST-L
    Each foglight is held in place with 2 nuts... one u get them u will see how the assembly works.
    The wires from the lights are maybe half a foot long, just long enough to reach the existing loom connections which should be tucked under the car somewhere near the bottom corners of the radiator... Poke ur head under the front bumper n u will find them..
    Finally the switch connection is just right near the headlight switch loom. It should be covered in that rubbery foamy stuff...
    Cutting the hole in the dash is a pain in the arse but if your handy with a power drill and a wood or metal file you will be sweet...
    You could try to use a jigsaw but its will be really tight and chances of cracking the material around the hole ur cutting will be fairly high...
    Good luck with it!
  5. CMA
    CMA New Member
    VZ SV6
    Thanx very much for that info Jesterarts, should be a big help when i get around to doing it. I've only had a quick look but i think my wires are tucked up on one side only and may only be one length (one light will have enough length but the other may not) if that makes any sense.
    Thanx anyway
  6. Lloyd1986
    Nah they will be tucked up on both sides. If you were looking under the front left side of the car and saw two sets of spare plugs, one is for a second horn.
  7. Fourzer0
    Fourzer0 New Member
    1. Get this bullbar.
    2. Get these
    3. Get this
    4. Get these
    5. Install them
    Done!! :) Any questions, please hesitate to ask.
    Mitch
  8. CMA
    CMA New Member
    VZ SV6
    If my car has got the wiring tucked up under the front for the fog lights, does that mean that the wiring loom for the switch will be there behind the dash below the headlight switch?
  9. evil_monkey
    evil_monkey New Member
    Australia
    Holden
    most likley
